Discussion topic: My sky keeps freezing
This message was authored by: Annie137
My TV and sky just keeps freezing and I think there is a problem with the sky streaming
Re: My sky keeps freezing
@Annie137 streaming video requires a strong stable WiFi signal reaching the device you are using . Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
Avatar for Annie137
But its saying my Internet is good,  I just need someone to exchange the black box as I believe its that
