2
This discussion topic has been answered Discussion topic: Broadband connection issues
This message was authored by: Henry_Ker
My sky broadband has been working intermittently today as it keeps disconnecting. I've run tests and it appears everything is fine in my area, but the modem is being temperamental. Can someone please assist
Re: Broadband connection issues
@Henry_Ker
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@Henry_Ker
Avatar for Henry_Ker
Thank you, I ended up having a Sky engineer coming out to resolve the issue 🙂
