Discussion topic: Broadband issues
This message was authored by: Papahet
Broadband issues
I received my new sky max hub but it won't connect to my sky
Re: Broadband issues
@Papahet
What is happening when you try to connect a device to your wifi network and what device is it ?
Avatar for Papahet
  • The hub is the new white sky max hub for some reason it doesn't connect to my sky TV for me to access my apps such as Netflix YouTube prime
@Papahet what Sky TV system do you have? If the problem TV is using a Sky Q mini box then things will have changed. The new hub cannot be connected directly by WiFi to Q minis instead using the WPS buttons on the mini and the main Q box connect the mini that way.
