Discussion topic: My sky internet keeps going off
This message was authored by Kirmo This message was authored by: Kirmo
Is there a problem with the internet in the Grimsby area
Re: My sky internet keeps going off
It is more likely an issue with your connection so try running through this as it should run a line test and if an external issue is found you can book an engineer repair:
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
This message was authored by Mark39 This message was authored by: Mark39
You can check for known, significant outages by logging in here: https://www.sky.com/help/servicestatus#/uk/issues
If there's a fault with just your line, it won't be shown there.
