Discussion topic: My internet keeps loosing connection
This message was authored by: StaceyH90
My internet keeps cutting out loosing connection then reconnecting couple of minutes later. It has been happening the last 3 days and is getting really frustrating as it's happening very frequently. What can I do to fix the problem all tests are coming back normal
Re: My internet keeps loosing connection
@StaceyH90
Could you post your router statistics
