Discussion topic: My internet keeps dropping out constantly!
Message posted on 21 Oct 2025 08:04 AM
The service checker is useless. My internet is dropping out several times a day, the middle light is flashing orange, or simply not lit and the service checker states it's all working fine. The lack of WiFi says otherwise.
I pay an obscene amount of money for sky, and the services are rubbish. Please can someone either send me a new hub, or fix this issue, or I'm leaving sky. What am I even paying for?
Message posted on 21 Oct 2025 08:07 AM
Re: My internet keeps dropping out constantly!
@Lynsey9
Threatening to change provider is pointless here. You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
