Discussion topic: My internet has been dropping in and out
Message posted on 22 Mar 2024 07:09 PM
My internet has been dropping in and out since 1am this morning, this happens every couple of minutes, sky says there are no faults in the area,
Message posted on 22 Mar 2024 07:40 PM
Re: My internet has been dropping in and out
@Kat40 Just checking the service checker does not always show there is a fault.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 22 Mar 2024 10:03 PM
It won't let me, the sky hub just keeps resetting itself, it was fine before but started at 1am this morning it must have reset 500 times now if not more the longest it's been ok for is 13 minutes
Message posted on 22 Mar 2024 10:05 PM
@Kat40 You don't need the broadband to be up to do this test as it can be done using mobile data.
Message posted on 22 Mar 2024 10:29 PM
Shows no faults, but there clearly is it shouldn't just be resetting itself over and over
Message posted on 22 Mar 2024 10:37 PM
@Kat40 Does the power light go red or stay green when it is doing this or go out completely?
Message posted on 22 Mar 2024 10:44 PM
Goes out, then comes back on red till all lights come back on, then turn green, then it will stay on for a few minutes then do it again, it's been all day
Message posted on 22 Mar 2024 11:01 PM
@Kat40 Are you able to try the router in another plug socket and is the router making any funny noises?
Message posted on 22 Mar 2024 11:25 PM
I've tried it in a different plug and no it's not making any noises
Message posted on 22 Mar 2024 11:46 PM
It's a new hub it was only connected 1st Feb 24
Message posted on 23 Mar 2024 08:55 AM
@Kat40 Was the same thing happening to your old hub and why did you have to change it?
Message posted on 23 Mar 2024 10:57 AM
Changed from vodaphone back to sky, beginning to wish we hadn't now
