Discussion topic: My hub and connection
This message was authored by: Tommy08
Done checks and turned off a d on only 2 garden lights and a orange light on can't get Internet
Re: My hub and connection
@Tommy08
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
