25
This discussion topic has been answered Discussion topic: My broadband
This message was authored by: Rach78
My broadband
Hi I got my new broadband install yesterday
Avatar for Rach78
This message was authored by: Rach78 Answer
Re: My broadband
Thanks for your help I have sky coming out to resolve this for me 🥳
Re: My broadband
@Rach78
Ok, do you have a question about it ?
Avatar for Rach78
Re: My broadband
Hi my landline has been disconnected since installation
This message was authored by: peter-marlow+1966
Re: My broadband
You plug the phone  into the phone  socket  in the back of the hub  for it to work, once you go full fibre  the old phone line  does not  work  any more
P c marlow
Avatar for Rach78
Re: My broadband
Oh I wasn't told this I need to call them and they have put my router in wrong room
Re: My broadband
Is your  router connected to  one of these?
 if so you  have full fibre  to the property  and you just need to plug  your  house phone  into the uk phone  socket  on the back of the router
P c marlow
Re: My broadband
@Rach78 If you can take a look at the link below, say which hub you have and also a link about the hub lights! If you do have the Sky Broadband Hub, then you need all 4 Lights lit green, and the phone does take 24-48hrs all to gel together after a change over and connected to the back off the hub!
Avatar for Rach78
Re: My broadband
It's screwed to wall lol no way I can take it off I don't think
Re: My broadband
Your  router  is screwed  to the wall ?
P c marlow
Avatar for Rach78
Re: My broadband
Avatar for Rach78
Re: My broadband
Last pic is where I can take it off
Avatar for Rach78
Re: My broadband
Sorry I can't take it off
Re: My broadband
@Rach78 Does not matter about the picture, where are you located area wise, UK or the ROI!
Re: My broadband
That is not your  router , that is your  optical network terminal that the router  is plugged  into
P c marlow
Avatar for Rach78
Re: My broadband
I'm confused
