01 Sep 2023 11:13 AM
Two days, and still heard nothing from SKY, in regards to fixing my wifi. No message, no phone call, no email, nothing. I work from home. I need my wifi.
01 Sep 2023 11:15 AM
Posted by a Superuser, not a Sky employee. Find out more@JayRok32 Have you ran the broadband test to see if it picks up this fault. Where is that you are from as there are reports outages in a few areas in the past few days with Sky.
01 Sep 2023 11:35 AM
Im in glasgow. Ran tests. They say it needs to be fixed. Still waiting....
01 Sep 2023 12:13 PM
Posted by a Superuser, not a Sky employee. Find out more@JayRok32 Did they say it was an outage or just at your property?
01 Sep 2023 12:50 PM
they havent said ANYTHING. I havent heard from them since...
01 Sep 2023 04:22 PM
Posted by a Superuser, not a Sky employee. Find out more@JayRok32 Is the fault still present after they said it was fixed? Has the service come back on?
01 Sep 2023 05:03 PM
Nope. STILL waiting.
01 Sep 2023 07:54 PM
Posted by a Superuser, not a Sky employee. Find out more@JayRok32 Have you called Sky back to see what is happening with your connection to see if the fault still is not fixed and why?
01 Sep 2023 08:15 PM
I called them...."lines are busy".....,30 minutes later, "All our lines are busy.....and blah, blah, blah". The engineers that came out, said it SHOULD, be working now. NOPE. I asked them why this happened, their answer was, "it happens all the time, people at SKY just pull plugs, its a mess there, wires and plugs everywhere". **bleep**!!!??
