Discussion topic: My broadband keeps dropping
Message posted on 26 Dec 2023 10:14 PM
My broadband keeps dropping and everything says good signal and connected so I don't understand why this is happening?
Message posted on 26 Dec 2023 10:23 PM
Re: My broadband keeps dropping
'Good signal' is WiFi from the Hub. If the external internet connection to the address is failing, the signal will still be 'good' but it won't be going anywhere.
Message posted on 26 Dec 2023 10:29 PM
Ok thank you. Do you know how I fix that?
Message posted on 27 Dec 2023 07:04 AM
@Kim147 if the internet light on your Sky hub is out or amber it indicates a loss of external connection. You can find out if Sky arexaware of an issue affecting your line by using the connection test in the My Sky app which works over a mobile connection. If there isn't a known fault call Sky to report the loss of connection so they can get your line checked by an engineer.
