Discussion topic: My WiFi not working
This message was authored by: DezzyD
My WiFi not working
My WiFi is not working & the app is lying say everything it's all up & running. It's clearly saying no internet on my tv so had to disconnect my phone of the WiFi to us my data to check the app.  & it's definitely lying..
This message was authored by: LorraineG
Re: My WiFi not working
Mine also went totally down about an hour ago. My app is also lying saying all is fine haha. What's the phone number on a non sky mobile please to report this?
This message was authored by: Nikjs
I am facing the same issue right now
This message was authored by: Ganny1
I am facing the same issue as well
This message was authored by: MrB2025
Same
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still not working by 7am use this link to check to see if there are any broadband problems or outages nearby.
