Discussion topic: Wifi
This message was authored by: Jjr3
Wifi
No wifi, app says i have wifi
Re: Wifi
@Jjr3
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 0700:use this link to check to see if there are any broadband problems or outages nearby.
