Discussion topic: Multiple SSIDs
Message posted on 07 Dec 2024 09:58 PM
Multiple SSIDs
I've recently had fibre installed and upgraded the old black sky hub to the new white Sky Max hub. I'm currently trying to connect my wireless printer and it's saying there are 'multiple networks broadcasting with the same SSID' and, as such, refuses to connect.
Does anyone know why and if so, how to prevent this?
Thank you
Message posted on 07 Dec 2024 10:03 PM
Re: Multiple SSIDs
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Message posted on 07 Dec 2024 10:29 PM
Re: Multiple SSIDs
Thank you but, unfortunately, I've just tried both suggestions to no avail. The security was already on WPA2 and the message persists even when the 5ghz disabled.
