This discussion topic has been answered Discussion topic: Internet isn’t connecting
Message posted on 12 Sep 2025 08:09 AM
My bill is paid. But my internet isnt working
Message posted on 12 Sep 2025 08:12 AM
@MattyHol
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@MattyHol
