Discussion topic: Moving home
This message was authored by: leepotter912
Moving home
I am trying to set up a moving date but it keeps saying I have to send back my equipment! Why do I need to send back my stuff when I don't want to leave Sky?
Re: Moving home
@leepotter912
Depends what hub you have at the minute and how long you have had it for.
Could you enter you full address below and post the table after removing your address from the image
Avatar for leepotter912
Re: Moving home
Re: Moving home
@leepotter912
The only thing that has changed would be sky are changing away from the pstn system to internet voice calls which require the sr203 hub which has a analogue telephone adapter on the back
Which hub do you have
Re: Moving home
My router has voice calls as it is one of the lights on the front says voice.
Re: Moving home
@leepotter912
What speed have you opted for.  I see from the table that g.fast is mentioned with no indication of availabilty.  Sky does 150 Mbps g.fast but that is starting to reach end of life
Re: Moving home
I currently have around 62 mbps which is the fastest Sky currently do in our area.
Re: Moving home
@leepotter912
Was the table above for your new address ?
Re: Moving home
Yep 👍🏻
Re: Moving home
@leepotter912
Could you do the same for your new address.  I can't why they want your old hub back when its the latest hub for superfast fttc and fttp
Re: Moving home
It was the new address I got the table from. I think I will have to give them a call. Thanks for your help
