9
This discussion topic has been answered Discussion topic: Moving from Virgin to Sky - how does Sky's internet get connected?
This message was authored by: adamcollis
Hi.  Sorry to ask such a basic question but Sky's AI chatbot was as useful as a chocolate fireguard....
I'm trying to figure out what installation work is going to be needed if I go with Sky for broadband services.  Can anyone advise?
I'm currently with Virgin Media and have a fibre connection into the house.  I haven't had a BT account for deades but there are still some telephone wires coming through the wall, but I have no idea if they're usable.
What I don't know is whether Sky would install a satellite dish, fibre-obtic or reuse those old copper connections.
As it's quite an old property with various damp issues I'm keen to avoid any new drilling, hence I'd like to know what Sky would do before I sign up for their services.
TIA, Adam
Re: Moving from Virgin to Sky - how does Sky's internet get connected?
@adamcollis wrote:
My conclusion is that Sky 'should' be able to use the existing line, although who knows whether the cable through my wall is still good.
A slight correction: they probably could, but I don't think they will.
Even Superfast (80Mbs) service is provisioned over FTTP where that's potentially available.
Sky is a satellite television company, but not a satellite ISP (so Sky dishes cannot carry an internet connection)
Sky broadband will be provisioned over a new optical connection if your area has Openreach / OpenEIR FTTP infrastructure, otherwise it will use copper telephone cabling.
Sky and other Openreach ISPs cannot use Virgin cabling of any kind.
@adamcollis
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Avatar for adamcollis
Thanks @Timmy.  Here's an image of the complete table:
With my limited understanding of the tech, it looks like the BT line is available for Sky, but does this mean the best Broadband connect I could expect from anyone except for Virgin is 80Mbps?
Note that in a 'fibre priority area' there's no option to use existing copper as ISPs simply cannot order wholesale service over it.
@adamcollis
My eyesight isn't quite up to reading that on my phone but it appears FTTP is available with some kind of caveat on the installation.
@adamcollis
So gigabit broadband is potentially available through new overhead fibre optic supply but it's not a straightforward job to get in place.
That's the 'OH External CBT Complex L2C' bit.
@adamcollis
As it's not a fibre priority area an Openreach ISP could in theory sell you FTTC over copper, but I don't think any will now do so because they are incentivised to help get the national switch to FTTP moving.
Hi @TimmyBGood ,
Thanks so much for taking the time to help me understand matters, it's definitely put my mind at ease.
Thank you! Adam
