Discussion topic: Moved house
Message posted on 30 May 2026 07:22 AM
Moved house
I've moved house. I upgraded to Sky Full Fibre Gigafast. I took the only hub to the new house as one wasn't deleivered and it's not turning on at all. I expected a new hub to be delivered as this is what I've had with all previous sky products, although non have, and my old hub isn't working.
Message posted on 30 May 2026 08:02 AM
Re: Moved house
@JoshRobini with a home move you do take your hub with you that is correct. The servicecat your new home will becaxtivated on the date you were given when you booked the move until thst time the hub wont work.
Message posted on 30 May 2026 08:19 AM - last edited: 30 May 2026 08:22 AM
Re: Moved house
A complete absence of lit LEDs would indicate a power supply problem.
The Sky Broadband Hub and the Max Hub are compatible with FTTP.
Message posted on 30 May 2026 09:01 AM
Re: Moved house
@JoshRobini Do rule out the obvious first and check that the socket you're using works. It's otherwise odd that a working router should suddenly stop working in a new location. Is the ONT showing any green lights?
What speed is it you're on?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
