Discussion topic: Move ONT box
This message was authored by: MichelleK203
Move ONT box
I need my ONT box moving from my kitchen into another room as having a new kitchen fitted and it is in the way.
I didnt want it there in the forst place but it was during coved and they said that was the only place they could do it by the door.
Does anyone know who I contact for this?
Re: Move ONT box
@MichelleK203 If Sky supply your broadband you need to contact Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Move ONT box
@MichelleK203
For information: there's at least one supplier of a DIY relocation kit for an ONT.
This message was authored by: Tommy2
Re: Move ONT box
I have seen those but I owuldnt recommend it as you still have to connect to the original one.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
Re: Move ONT box
@Tommy2
It's a back-to-back junction with the original fibre and then a long length of pigtail so the original ONT can be moved.  The theory is fine (and optical junctions are used all the time on in-premises business networks) but the legitimacy of messing with what's still technically the national network is perhaps dubious.
Re: Move ONT box
Yeah im aware of what it is, but it might not be helpful in this case as the OP states that the opriginal one is in the way
