Discussion topic: Max pods.
This message was authored by: ShellMyBell1967
Max pods.
I had 3 new max pods installed yesterday, 31/5/26. This morning, only 2 are connected. 1 has a flashing white light, and no matter what I try with the connection guide, it will not find the pod on mysky app. Any help or thoughts, please?
Re: Max pods.
@ShellMyBell1967 try moving the faulty pod closer to the hub or another pod as the units require a decent connection to operate. If the isssue continues call Sky as they msy need to send out an engineer to optimise the system. In marginal conditions having an internal door open or closed can stop connection.
