Discussion topic: Macbook air
This message was authored by: TB248
Macbook air
Hi, I'm having an issue with the Wi-Fi on my MacBook Air.
The Mac keeps disconnecting from the Sky Max Hub every few seconds, and when it's connected, websites are extremely slow. I'm sitting right next to the router, so signal strength shouldn't be an issue.
I've tested the same Mac on my iPhone's hotspot, and it works perfectly with no disconnections, so the Mac itself seems fine. I've also tested another device on the Sky Wi-Fi, and that works normally.
I've restarted both the Mac and the Sky Max Hub and forgotten/rejoined the Wi-Fi network, but the problem persists.
I'm going to try disconnecting the 5 GHz and see if the 2.4 GHz works any better.
Is there any way to have the Max Hub checked or arrange a replacement? It seems to be an issue with the Hub's Wi-Fi connection to this Mac rather than the broadband connection itself.
This message was authored by: ItWasAllMichele
Re: Macbook air
Posted by a Sky employee
Hi there @TB248 I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: nerf
Re: Macbook air
I am having this exact same issue on my M1 Air!!! Its so strange, I've even played around with DHCP leases etc to no avail
This message was authored by: RocketMan111
Re: Macbook air
is your hub configured for WPA-2 or WPA3-T
Avatar for TB248
Re: Macbook air
It is really strange, isn't it?
My girlfriend has the newest MacBook Air, and it has no issues whatsoever.
