4
Discussion topic: Low broadband speed. Over 2 weeks below1Mbps
This message was authored by Richard+Jon This message was authored by: Richard+Jon
My broadband speed is about0.8Mbps - the lowest was0.2Mbps. I can't find anyway to contact Sky direct so they can do something
Richard+Jon
This message was authored by Richard+Jon This message was authored by: Richard+Jon Answer
Re: Low broadband speed. Over 2 weeks below1Mbps
I use ethernet and the router is a Sky type    SKYN2D31
@Richard+Jon
How are you measuring the speed? Ethernet or wifi
Can you post your hub stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Richard+Jon
@Richard+Jon
Your hub stats as shown above will help us in determine if its an external fault, the router or the cable
@Richard+JonThose numbers and letters look like your SSID for your Wi-Fi. Which router do you have from the link below.
