Discussion topic: Loss of connection
This message was authored by: Jasonleejones
Loss of connection
I loose connection all the time
Re: Loss of connection
@Jasonleejones
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
