Discussion topic: Internet cutting out
Message posted on 13 Feb 2025 06:19 PM
WiFi has been cutting out and has been for days. Keep doing SKY checks and says everything is fine but the internet keeps dropping out
Message posted on 13 Feb 2025 06:20 PM
Re: Internet cutting out
@Internet2
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
