Discussion topic: Loss of WiFi in parts of our house
This message was authored by: WiFicover
There is a significant drop off of WiFi signal in the rear of our house.
This is disappointing as I've upgraded to Sky Max.
What can be done to boost the signal?
Re: Loss of WiFi in parts of our house
@WiFicover Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homeswith solid internal walls. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
