Discussion topic: Internet keeps going off
Message posted on 11 Sep 2025 02:31 AM
Internet has gone off 3 times now, we have done all the checks but it's saying everything is OK.
Message posted on 11 Sep 2025 02:55 AM
Re: Internet keeps going off
Message posted on 11 Sep 2025 06:09 AM
@Keithannlily-ann @Ambskyyyy123
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband isn’t working after 7am use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
