Discussion topic: Loosing connection/poor connection
This message was authored by: Rasna
Ever since I have changed from BT to Sky, I have been having poor connection or loosing connection when I am on my work Teams calls or just generally browsing on my phone.
I was told that this Sky broadband I take out would be much faster than what I had previously with BT. But instead I have been having trouble ever since I changed over to Sky. I left it a while, thinking maybe it's a new line and needs time to settle down. But the problem keeps going on and getting worse actually.
Re: Loosing connection/poor connection
@Rasna  Is this only devices connected to the Wi-Fi that you are having issues with or is it also devices connected by hardwire or ethernet.
Avatar for Rasna
Hi, it's mainly WiFi related (teams calls, mobile phone). However, the connection I have on my device that is via hardwire, is also slower than before
@Rasna Could you please post your router stats following the link below.
Avatar for Rasna
Router Statistics
System Up Time: 301:09:49
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 54212207 191090664 0 36773 58531 301:07:55 LAN Up 39851178 3832405 0 14017 301 301:09:49 WLAN (2.4 GHz) Up 23043324 12778140 0 13674 552 301:08:04 WLAN (5 GHz) Up 291027012 44564159 0 0 0 301:08:01
Broadband Link Downstream Upstream Connection Speed 159900 kbps 30000 kbps
@Rasna  Where is your router kept and do you have a good signal throughout the property?
Avatar for Rasna
The router is kept in the living room. The same place as my previous router from BT
@Rasna  Can you check to see if any of the directions in the link below help with the Wi-Fi.
https://www.sky.com/help/articles/improve-the-wi-fi-signal-to-your-devices
