6
This discussion topic has been answered Discussion topic: Loosing Connection.
This message was authored by: Sadlebags76
Loosing Connection.
3 to 4 times a day we loose connection. We turn off a the plug for 30 seconds. We press the reset buttom for 30 seconds, but still this is happening. What else can I do?
This message was authored by: cookiemonsteruk Answer
Re: Loosing Connection.
@Sadlebags76
You can run the service checker using 4g/5g mobile data and it will run diagnostics
@Sadlebags76 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Avatar for Sadlebags76
Thank you. I have done so and it doesn't find a fault. This is because at the minute it is ok. I'm not sure that I can run the test when the internet is down can?!
@Sadlebags76
@Sadlebags76
If it finds an external fault it should let you book an appointment directly to openreach
This message was authored by: GaryD1
No . Still cannot get my Sky Q to connect. Sky box making loud noises and keeps going off and on. Can someone help . This is becoming a problem in the house with no sky tv
@GaryD1 Have you called sky!
