Discussion topic: Loose connection
Message posted on 29 Jul 2025 09:28 AM
Loose connection
My sky boxes inside and outside my house are both loose. I keep losing signal This has been going on since Saturday 26/7. My son works from home so as you can imagine is causing a problem.
Message posted on 29 Jul 2025 09:48 AM
Re: Loose connection
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
