8
This discussion topic has been answered Discussion topic: Logs error - any help?
This message was authored by: Jimmy81
Hey All - playing games online that keep dropping out and get following logs:
15:42:44 syslog: [75226.638000] eth2 (Ext switch port: 2) (Logical Port: 10) Link UP 1000 mbps full duplex
15:42:58 syslog: [75240.796000] eth2 (Ext switch port: 2) (Logical Port: 10) Link DOWN.
My internet is good, 675mbs so unsure what it means!
Avatar for Jimmy81
This message was authored by: Jimmy81 Answer
Re: Logs error - any help?
All fixed - rogue device in port 2.
I removed that and everything works and logs are good!
@Jimmy81
Which ethernet port on the sky hub is the ont plugged into?
@Jimmy81 See the link below. Ethernet connection on Lan port number 2...
Port numbers on SR203 | Sky Community
Avatar for Jimmy81
Hey! ONT is plugged into port 4 labelled WAN. It's always been in that one and gaming was fine.
Ethernet cable from Sky box (black one) is in port 1.
if I unplug the Ethernet cable from my PC I still get the same issue on wifi, albeit it downloads a bit longer but still drops off.
im wondering if it's a fault with the sky box?
@Jimmy81 Just swap the ports over port 1 and port 2, see if the error log changes the port error, would disconnect the Q Ethernet in case it is causing a port issue....
Avatar for Jimmy81
@Jimmy81 Do keep us in suspense, what device was causing the network port issue!
Avatar for Jimmy81
My car charger Ethernet cable!
Cable must be defunct or something, popped that out and the pc came alive!
@Jimmy81 If you need the charger on Ethernet you could always try a Gigabit Switch inbetween both incase it's just an oops in comms, sometimes happens cost's are about £20 + couple £'s for a short Ethernet cable if you do not have one lying around!
