13 Jul 2022 08:48 AM
Hi. I purchased a Velop Atom Pro off Amazon last night because I'm fed up of the lag gaming when I'm sat right next to the Sky Hub.
Turns out it looks like I may have purchased the wrong item as I'm only getting superfast speeds. Do I need to purchase a VDSL modem/router? If so any recommendations?
13 Jul 2022 08:51 AM
Sorry it's Atlas Pro 6.
13 Jul 2022 09:24 AM
Will need to check the velop to see if it uses mer, dhcp option 61 to authenticate if so the model below will be the best option for the modem bridge
Tp link td w9970
Instructions for setting up tp link td w9970 as modem bridge
select sky vdsl from isp list
https://www.tp-link.com/uk/support/faq/1332/
13 Jul 2022 09:41 AM
At the minute the is no info on linksys to confirm whether it supports dhcp option 61 for authenticating with sky servers. In other words it looks like it supportr PPPOE which only works with sky ireland.
Theres nothing stopping you from switching wifi off on the sky hub and switching the velop to access mode to avoid double nat
