Discussion topic: Keep losing internet connection
Message posted on 19 Aug 2024 10:56 AM
All over the weekend and this morning, the sky Q router keeps losing internet connection (middle light goes off, then orange, them back to green) this takes about 1min. Sometimes it will not do it for an hour or so, but other times it's every 10min, I can see no pattern.
Message posted on 19 Aug 2024 12:53 PM
Re: Keep losing internet connection
@Ickle-frog Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 19 Aug 2024 03:11 PM
Message posted on 19 Aug 2024 03:20 PM
@Ickle-frog Are you clicking on broadband to run an updated test?
Message posted on 19 Aug 2024 03:50 PM
Yes, I just tried again when it was out, and had a message that the test was not available - after 3 times it tells me what I should have. Then if retest (by that time the internet was back) it's all green.
Is it possible that my box is over heating, I never turn it off and it is quite warm (I did re boot it yesterday to see if it would clear any issues, but it was only powered off for 10min)
And thanks for your help
Message posted on 19 Aug 2024 03:56 PM
@Ickle-frog I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147/
Message posted on 19 Aug 2024 04:22 PM
Hi there! Thank you for escalating this. We have sent an invite to @Ickle-frog.
Message posted on 22 Aug 2024 12:19 PM
Update-We are closing this session now due to no further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
