Discussion topic: Issues with internet connection
Message posted on 20 Sep 2025 12:36 PM
The box is constantly flashing between orange, then red. It's dipping in & out constantly. Run a test on here but it says it's fine. But clearly there is still an issue.
Message posted on 20 Sep 2025 12:39 PM
Re: Issues with internet connection
@Kerry177
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 20 Sep 2025 12:48 PM
Thank you ☺️
I will try these, failing that I will just give sky a call.
