Discussion topic: Wifi
This message was authored by: julepease2704
Wifi
Wifi slow, sky buffering - internet keeps dropping out
Re: Wifi
@julepease2704
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
