Discussion topic: Wifi- Connection failed
This message was authored by: Patryk94
Hi , on the app all the checks says theres WiFi in my house, but all my devices cannot connect to wifi and when I try to connect it says Connection Failed, wifi went off yesterday on Saturday at around 5pm and its now 8am on Sunday and still nothing.
This message was authored by: Me134
Re: Wifi- Connection failed
Do you mean that none of your devices can connect or only some? If only some, what are they and where are they in relation to the router?
Do you have any lights on the router? What are they?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
Avatar for Patryk94
All my devices are disconnected and all the lights are green on my hub, nothing is connected in my house, my tv has not wifi, my PC, my ring doorbell. But hub seems to be having all green lights on so is the city fibre box
Avatar for Patryk94
Its all fixed now, it came back to live itself.
