Discussion topic: Issue
Message posted on 19 May 2025 12:48 PM
Issue
I have no wifi connection, previously been running slow, have gone through all troubleshoots but still not working
Message posted on 19 May 2025 12:56 PM
Re: Issue
@Kim162
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
