02 Oct 2024 12:39 PM
I have just bought the new Gigi fast broadband but done a speed check on 2 apps the morning and the down load speed was 30 it can't drop 660 from the hub to the device
02 Oct 2024 01:16 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat device are you testing on?
How is it connected to the hub?
What speedtest service are you using?
Please post a screenshot of your result.
02 Oct 2024 01:18 PM
I have tested on my iPhone and then my Xbox series X the series x gave me 70 speed
02 Oct 2024 01:31 PM
Posted by a Superuser, not a Sky employee. Find out moreOkay and what about the other questions?
02 Oct 2024 01:54 PM
just done these recently sky is saying 693 to the hub it's a sky connecting full fibre and
02 Oct 2024 01:57 PM
Posted by a Superuser, not a Sky employee. Find out moreYes okay so all these tests are over WiFi. Sky do not guarantee the speed you are quoting over WiFi, its ethernet only. No ISP can guarantee you will get 600mbps over WiFi because its just so unpredictable.
02 Oct 2024 02:06 PM
Ok thanks mate
