Discussion topic: Internet speed is awful
This message was authored by Psteer This message was authored by: Psteer
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN MER 94750097 158762287 0 4425203 5631228 109:50:33
LAN Up 14263031 11916923 0 8851228 2571750 109:52:37
WLAN (2.4 GHz) Up 1973680 477 0 9436 0 109:50:45
WLAN (5 GHz) Up 131496979 68720133 0 0 0 109:50:45
Broadband Link Downstream Upstream
Connection Speed 45439 kbps 13255 kbps
Line Attenuation D1(19.4 dB) , D2(36.1 dB) , D3(51.4 dB) U0(11.6 dB) , U1(31.1 dB) , U2(43.4 dB)
Noise Margin 2.7 dB 5.5 dB
Re: Internet speed is awful
@Psteer
Your speed is around 45mbps, this looks to be about the best you can achieve for the length of your FTTC line. If you want better speeds you may want to see if full fibre is available to you.
I am NOT a Sky Employee
