Discussion topic: Internet problems
This message was authored by JamieLH1 This message was authored by: JamieLH1
Internet problems
My sky connection is not working and sometimes different devices says it has the wrong password. Any ideas of what is going wrong and how to resolve it?
Re: Internet problems
@JamieLH1 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
This message was authored by MARKIE52 This message was authored by: MARKIE52
I HAD THIS A FEW TIME BEST WAY IS TO TURN ROUTER OF FOR 5 MINS THEN REBOOT IT ALSO THERE A RESET BUTTON ON ROUTER CAN PRES THAT  ANDRE SETT IT THE PASSWORD IN ON A CARD THAT COMES WITH THE ROUTER OR ITS ALSO ON THE ROUTER NEEDTO PUT IT ON ANY DEVICE YOU USE
