Discussion topic: Internet problems today and since last 10 days
Message posted on 03 Nov 2025 04:41 PM
Hi I am having intermittent issues with my internet can you check at your end if any issues this is repeatedly happening for last 10 days and I having trouble working from
home
Message posted on 03 Nov 2025 04:45 PM
Re: Internet problems today and since last 10 days
@Stoomula
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
