Discussion topic: My WiFi is not working
This message was authored by: VictoriaR96
Re: My WiFi is not working
@VictoriaR96
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
