Discussion topic: Internet not working
This message was authored by: Loretta189
4th light is orange on my router. Checks on the app.suggest my broadband and WiFi both fine but this is not right and I have no internet access on any devices across my household. I have turned off at plug for plus 30 seconds and left it a few mins to reset but still have the same issue.
This message was authored by: chelss10
Re: Internet not working
same! I've tested mine as well and it's telling me everything looks good
@Loretta189 @chelss10
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
