Discussion topic: Internet not working
This message was authored by: HOLLIE1991
Internet is down, the WiFi is not available, we have tried to turn it off and on again
This message was authored by: HarmerR
Re: Internet not working
I have the same issue. WiFi just stopped working. Hub has flashing green light.
service checker says everything is working which it clearly isn't otherwise I'd have wifi
anyone else have similar issue?
This message was authored by: JohnGordon1
I'm having the exact same issue.
So the wifi finally came back online for about 30 mins but gas has once again died for unknown reasons
All,
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
This message was authored by: not+my+real+name
Same here. The broadband is dropping on/off since yesterday evening. Sky app says broadband is perfectly fine.
@not+my+real+name
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
