Discussion topic: WiFi cutting out
Message posted on 24 Apr 2026 10:35 PM
WiFi cutting out
Hi
my WiFi has cut out various times today - maybe about 3 times and I've never had that happen since being a Sky customer and I haven't changed anything or moved any of the devices - so nothing has been done which I would expect to affect the WiFi.
each time I test, it says it looks like there is a problem and then to test again and then when I do that it works again which is incredibly my frustrating.
can you advise what might be causing this issue and share troubleshooting steps
thanks
Message posted on 25 Apr 2026 05:32 AM
Re: WiFi cutting out
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
@Madison21
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
