Discussion topic: Internet not working
Message posted on 07 Dec 2025 06:26 PM
broadband box is not working. There is only 2 green lights on middle light that should be green is off and flashes red every now and again.
Message posted on 07 Dec 2025 06:34 PM
Re: Internet not working
@Annamarie2
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
