Discussion topic: I have wi fi connection I have done a reboot but still nothing
This message was authored by: Sue999Tom
Wi-Fi not working reboot has not wirked
Re: I have wi fi connection I have done a reboot but still nothing
@Sue999Tom
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
