Discussion topic: Internet not working
This message was authored by: Charlotte__
My Internet has gone off ? When I've done a check it says its working but it's not ?
Re: Internet not working
@Charlotte__
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Charlotte__
Had you tried rebooting your broadband hub at the mains ?
