Discussion topic: Broadband not working
This message was authored by: Somu
Today afternoon onwards Sky Broadband stop working
Re: Broadband not working
@Somu
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
