Discussion topic: Internet not working
Message posted on 09 Nov 2025 08:11 PM
Green light off on internet box
Message posted on 09 Nov 2025 08:17 PM
Re: Internet not working
@Gailkay
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
