Discussion topic: Internet not working
This message was authored by: Chelsea691
My internet isn't working!  I need this sorted asap
Re: Internet not working
@Chelsea691
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
Use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
